F port antenna to coaxial adapter
Discussion in 'LEDs and Optoelectronics' started by pepi, Jul 28, 2018.
Thread Status:
Not open for further replies.
  1. pepi
    pepi
    Sep 20, 2017
    25
    Woodstock, GA
    Gee my post is missing:
    So here goes again, I have a tuner that as you can see has one of those lame F ports.
    I wanted to run coaxial cable to an FM antenna, to pull in a jazz station. The LEDs tube lights were creating noise in the second garage.
    So I bought a coaxial cable union, shaved off the threads. Once smoothed kept filing until, the smoothed end was small enough to insert.
    However, not to small because it needed an interference fit to hold it in place and provide a connection to the shielding of the coax
    Pep
    pepi, Jul 28, 2018
    #1
    1. Advertisements
  2. pepi
    Bluejets
    Oct 5, 2014
    2,649
    501
    Why not use the connecter made for the job?
    Many available, crimp or screw together units.
    Bluejets, Jul 28, 2018
    #2
    davenn likes this.
    1. Advertisements
  3. pepi
    pepi
    Sep 20, 2017
    25
    Woodstock, GA
    ? davenn likes this? ^^
    I'm going to assume you have never tried the conversion. And explain why the two type of connectors that were posted. Using common sense as your friend, are useless.
    Rear picture of tuner, the wire antenna has a female plug, on a male port. Meaning the port has a pin.
    Second logical observation, no threads on the housing.
    The port on the tuner needs a female connector. A coax is a male connector and also requires a female connecter.
    The logical solution is a union, both ends shown..
    pepi, Jul 28, 2018
    #3
  4. pepi
    Bluejets
    Oct 5, 2014
    2,649
    501
    Inlet was not visible as it had a makeshift hunk of junk stuck in it. Only went by the marking saying it was 75 ohm and your description as coax so as they say, don't shoot the messenger.
    Oh, and for any future help, best of luck.
    #4
    hevans1944 and davenn like this.
  5. pepi
    kellys_eye
    Jun 25, 2010
    3,611
    960
    West Coast, Scotland
    That's not an 'F' port. Show it without the plug in. It looks to me like a conventional TV (UHF) socket and you should always use the correct connector for the job or you simply introduce problems/issues with extraneous pickup, interference, whatever if you don't.
    Filing down a non-standard (for the job) connector won't help you.
    kellys_eye, Jul 28, 2018
    #5
  6. pepi
    davenn Moderator
    12,789
    1,605
    Sydney, Australia
    yes I did because it was the best logic !
    you logic was off base as you were/are trying to mate a F connector to a Bellinglee connector
    USE THE CORRECT CONNECTOR ON THE COAX :rolleyes:
    thread closed
    davenn, Jul 29, 2018
    #6
    hevans1944 likes this.
    1. Advertisements
Thread Status:
