ESR meter in the battery tester
caps
Jul 29, 2018
183
Jul 29, 2018
183
Hi everybody.
I constructed my ESR meter according to the known scheme of Manfred.
http://ludens.cl/Electron/esr/esr.html
The board was inserted into the battery tester.
The scale is 0.005-10 ohm.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Yes, that seems to be what you did.
caps
Jul 29, 2018
183
Jul 29, 2018
183
I am glad that it is clearly visible.
By selecting the measurement modes of this circuit, it was possible to achieve an almost sinusoidal signal.
caps
Jul 29, 2018
183
Jul 29, 2018
183
Specifications.
ЕSR-0,005-10Оhm
F-100kHz
Vpp-100mV
Measuring probes-50cm.
On the meter there are gold-plated contacts for connecting capacitors.
There is no potentiometer for zero adjustment, because there is no drift with stable power supply.
caps
Jul 29, 2018
183
Jul 29, 2018
183
The battery tester was chosen specifically to not use the eps tables.
Green sector.0,005-0,5 Ohm corresponds to the range of capacitors 10000uF-100uF.
The small sector.0.5-2 Ohm corresponds to the range of capacitors 100uF-10uF. Capacitors of small capacity fall into the red sector.
The scale was calibrated with precision, non-inductive resistors.
(*steve*)
25,510
25,510
Ok it seems you don't have a question. Perhaps you should have posted this in another section :)
However, I would advise you to double the frequency from 50kHz to 100kHz. ESR is typically specified at this frequency.
caps
Jul 29, 2018
183
Jul 29, 2018
183
I already wrote that my ESR meter works at a frequency of 100 kHz.
You can transfer my topic to another place, there are no problems.
(*steve*)
25,510
25,510
Fine, the original circuit you referred to use 50kHz.
Presumably your meter has fixed leads and hence the zero can be set one and forgotten. I usually use a set of dedicated probes for mine, but sometimes I change to another set (mine can use regular multimeter probes) and hence the lead resistance can change.
Whilst reading your thread, and also designing a circuit which needs Kelvin connections to a sense resistor and possibly polymer caps I have been wondering why ESR meters can't use Kelvin connections to the capacitor. If I needed to measure ESR in the region of a couple of millions it would make sense to have that sort of measurement.
caps
Jul 29, 2018
183
Jul 29, 2018
183
This meter was not designed for very accurate measurements of ESR. It is made for rapid express analysis of capacitors. Good-bad. Calibration was performed only for the limits of sectors,although it is possible to mark the scale more accurately.
My circuit is slightly different from the original and was made at a frequency of 100kHz.
(*steve*)
25,510
25,510
Perhaps you can post the circuit for the benefit of others.
One thing I didn't comment on earlier is the somewhat imperfect triangular waveform in post #3 in this thread that you describe as a sine wave.
caps
Jul 29, 2018
183
Jul 29, 2018
183
Does this somehow affect the measurement of the ESR capacitors?
(*steve*)
25,510
25,510
It does have a significant harmonic content so your measurement may be affected a little by it.
Having said that, I don't know if ESR meters typically use a more pure sine wave.
caps
Jul 29, 2018
183
Jul 29, 2018
183
Different meters have different signals.
caps
Jul 29, 2018
183
Jul 29, 2018
183
Tantalum capacitor, 220μF in the circuit.
