ESP8266-01 with Arduino Nano issues
Discussion in 'Microcontrollers, Programming and IoT' started by Steve Peart, Oct 12, 2017.
  1. Steve Peart
    Steve Peart
    Sep 16, 2015
    51
    3
    Hello All,
    First, I know I can technically just flash things to the ESP8266-01 without the Arduino. I couldn't get that to actually work so I wanted to use the ESP8266-01 out of the box as a Wifi connection for my arduino nano.
    I have looked at a lot of tutorials for this setup and found they vary here and there. I have tried a lot of them but I am not seemingly able to get the Nano to talk to the ESP8266-01.
    The 9VDC @1500mA is a 9V Power Supply I purchased online to give the ESP8266-01 enough current to not have it unable to perform. Should be overkill, but I read that the 3.3v out from the nano won't have enough on it's own plugged in via USB to make Wifi work.
    I included a graphic of the ESP8266-01 So you can also see which pins are which.
    The resistors in the middle-top area are a voltage divider so that the signal from the nano at 5V doesn't fry the ESP8266-01 which accepts 3.3V as HIGH. I read that somewhere too.
    The TX/RX Pins are going to regular Arduino digital pins so the Nano can communicate with the ESP8266-01 via Software Serial libraries, since you don't get extra TX/RX pins to use for this from the Nano.
    Here's the basic sketch I am trying to run:
    #include <SoftwareSerial.h>
    SoftwareSerial ESPserial(2, 3); // RX | TX
    void setup()
    Serial.begin(115200); // communication with the host computer
    // Start the software serial for communication with the ESP8266
    ESPserial.begin(115200);
    Serial.println("");
    Serial.println("Remember to to set Both NL & CR in the serial monitor.");
    Serial.println("Ready");
    Serial.println("");
    void loop()
    // listen for communication from the ESP8266 and then write it to the serial monitor
    if ( ESPserial.available() ) { Serial.write( ESPserial.read() ); }
    // listen for user input and send it to the ESP8266
    if ( Serial.available() ) { ESPserial.write( Serial.read() ); }
    I figured out that my connection to the ESP8266-01 needs to take place at a 115200 Baud rate based on some previous testing I did using an FTDI Connector and directly communicating with it through the arduino console.
    When I run this sketch, all I get is a little bit of gibberish at the beginning as output from the ESP8266-01, and the rest of the sketch prints out it's startup stuff fine. I type in AT commands and sometimes get weird characters, and sometimes a few question marks (?), etc.
    I am sure I am making a bunch of mistakes and bad assumptions in my wiring/coding, but I feel a bit stuck and could really use some help figuring out where I am going wrong.
    Feel free to ask me to test a voltage on something or any other questions and I'll provide whatever other details I can.
    Thanks!
    -Steve
    #1
    1. Advertisements
  2. Steve Peart
    24,089
    2,336
    You've recognised that the 3.3V output can not supply sufficient current. What have you done to supply enough current to the ESP8366? Have you wired up an external 3.3V regulator? If you're powering it from 9V it may get reasonably warm unless heatsinked or in a fairly large package.
    (*steve*), Oct 12, 2017
    #2
    1. Advertisements
  3. Steve Peart
    Steve Peart
    Sep 16, 2015
    51
    3
    Does powering the Nano with the 9V Adapter not give the entire circuit access to the current? Even the 3.3V line?
    #3
  4. Steve Peart
    Steve Peart
    Sep 16, 2015
    51
    3
    Also, assuming the 9v adapter current DOESN'T come through the 3.3V pin, I threw together a quick voltage divider for the 9V coming in to have a 3V line and that didn't work either. I am partially wondering now if the software serial cannot handle the 115200 baud rate to the ESP8266-01, but for me to change that, I'd have to flash the ESP8266-01 to change that config, which if I could do that, I would try to use it without the nano.
    #4
  5. Steve Peart
    24,089
    2,336
    The existing 3.3V regulator may be good for about 50mA, about half of what you want. A voltage divider is somewhere between useless and extremely wasteful.
    Get an external 3.3V regulator and use that.
    #5
  6. Steve Peart
    Abid Jamal
    Nov 13, 2017
    4
    Step 1: Turn On Your ESP8266 Module by Using Arduino Nano 3.3V Dc Output Pin. Remeber sometimes Arduino board is not delivering sufficient voltage to the ESP8266 module. You can use a 3.3 V ( Do not exceed input voltage from 3.3v) regulator ( AMS1117 ) to power this module. A voltage divider circuit is used to drop the Arduino 5V to ESP8266 3.3 V.
    Step 2: Here is the schematic Diagram, in my code I used Digital pin 2 as a Tx and D3 as an RX. [​IMG]
    Step 3: Open Arduino IDE and Paste the source code in the window just like shown in the picture.[​IMG]
    Step 4: You are ready to send At Commands to Your ESP8266 Module. Remember you will see a Garbage value during Serial Communication.
    AT – Will give OK on the serial monitor, if Not just unplug vcc Pin of ESP8266 Module for a moment and reconnect again.
    Send AT+RST – Command to Restart module / Optional Command
    Send AT+GMR – To get the firmware version
    Send AT+CWMODE? – Set Module to a Dual Mode Sucha as Standalone + Access Point mode.
    Send AT+CWLAP – Command to Search Nearby Wifi Access Point. Find your Wifi Name in the Search Result.
    Send AT+CWJAP="Your Wifi Name","Your Wifi Password" – Command to Connect to WIFI.
    Send AT+CIFSR – Command to Check Allocated Ip given by your Wifi to your ESP8266 Module/Optional Command.
    Abid Jamal, Nov 26, 2017
    #6
    1. Advertisements
