T
[email protected]
I'm a new user of Eagle, and I've only recently gotten into
electronics.
I hope this is the right group for this post, if not... could someone
tell me which is best?
When I run ERC, I get the following message:
EAGLE Version 4.16r2 Copyright (c) 1988-2006 CadSoft
Electrical Rule Check for E:/OtherSoftware/eagle/projects/ethernet/
ethernet_final.sch at 08/02/2008 03:17:00p
WARNING: Sheet 1/1: POWER Pin U1 VCAP connected to N$28
WARNING: Sheet 1/1: POWER Pin U1 VSS connected to GND
WARNING: Sheet 1/1: POWER Pin U1 VSSRX connected to GND
WARNING: Sheet 1/1: POWER Pin U1 VDDTX connected to VCC
WARNING: Sheet 1/1: POWER Pin U1 VSSTX connected to GND
WARNING: Sheet 1/1: POWER Pin U1 VDDPLL connected to VCC
WARNING: Sheet 1/1: POWER Pin U1 VDDRX connected to VCC
WARNING: Sheet 1/1: POWER Pin U1 VSSPLL connected to GND
WARNING: Sheet 1/1: POWER Pin U1 VSSOSC connected to GND
WARNING: Sheet 1/1: POWER Pin U1 VDDOSC connected to VCC
WARNING: Sheet 1/1: POWER Pin U1 VDD connected to VCC
WARNING: Sheet 1/1: POWER Pin IC1 AGND connected to GND
ERROR: OUTPUT and SUPPLY Pins mixed on net VCC
Board and schematic are consistent
1 errors
12 warnings
I can't figure out how to get rid of the error... I've spent a lot of
time rechecking all the connections in my .sch file and position on
the .brd, and I've still not been able to find the problem. I also
searched around for other people with the same problem, but haven't
found any good responses.
Can anyone help?
Cheers,
T
electronics.
1 errors
12 warnings
Can anyone help?
Cheers,
T
