Entering square bracket in text
Discussion in 'Announcements, Suggestions & Feedback' started by Harald Kapp, Feb 9, 2018.
  1. Harald Kapp
    8,385
    1,592
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    How do I enter square brackets within the text body of a post? It seems the forum software tries to interpret these brackets as formatting commands and deletes the if it can't evaluate them in a meaningful way.
    What I want to type is e.g.
    Code:
    array[i]
    My current circumvention is using a code box as above. I'm sure there is a more elegant way, but which one?
    #1
    1. Advertisements
  2. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    Unfortunately, the [ i ] tag is the BBCode for italics, so I don't think there's way to use it within a post, unless it's in a code box or has additional spacing to break the tag.
    I've been testing out the next version of XenForo and they have an "inline" code option (and there's a plugin for this version to do the same). This means that you can insert code snippets within the body of text. Here's an example image I found on their forum:
    Would that be a useful workaround? I don't think it's something I could fix entirely, but adding inline code options may help. If it's not much different to using the existing code tags, I'll leave it be - but I'm happy to add it if it's useful.
    Ian, Feb 9, 2018
    #2
    1. Advertisements
  3. Harald Kapp
    8,385
    1,592
    why, yes.
    #3
  4. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    Excellent :D. I've installed this now.
    Here is is in action if you want to use the [i] string in a post :).
    You just need to wrap the inline code with the [ICODE] tags. I'll see if I can add it to the WYSIWYG editor.
    Ian, Feb 9, 2018
    #4
  5. Harald Kapp
    8,385
    1,592
    [ and { and / and ]}\
    Really nice, thanks Ian.
    #5
  6. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    No problem! Glad that we've got a quick fix in place :)
    I'm having problems adding the code in to the editor, but I'll persist and see if I can get it in to the "insert..." menu. If I can't get it there, then it may need to be used manually for the moment (until we upgrade to XF2 in the future).
    Ian, Feb 9, 2018
    #6
  7. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    I should also mention that square brackets should normally work (i.e. [ and { and / and ]), but they'll disappear when using one of the tags listed on this page:
    https://www.electronicspoint.com/help/bb-codes
    [i] [b] [u] will probably be the most common ones, especially "i" in programming related posts. It's a shame that the forum software doesn't invoke them only when there's a matching closing bracket, as that would avoid the problem.
    Ian, Feb 9, 2018
    #7
  8. Harald Kapp
    8,385
    1,592
    The software seems to be better than you think: it amends the "missing" closing brackets ;)
    #8
    Ian likes this.
  9. Harald Kapp
    24,384
    2,416
    What's the problem with array[i]?
    (*steve*), Feb 9, 2018
    #9
  10. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    I had to view your post to see how you did that! A very clever workaround using invisible [size=3] tags within the brackets to break the auto parsing :D.
    Ian, Feb 9, 2018
    #10
  11. Harald Kapp
    24,384
    2,416
    You're giving away all my secrets :)
    Another way is if you set up the censoring to change \[ into [ and \] into ].
    #11
    Harald Kapp and Ian like this.
  12. Harald Kapp
    8,385
    1,592
    I actually had tried these escape sequences before posting.
    #12
  13. Harald Kapp
    24,384
    2,416
    Yeah, they're not implemented here, but there is a way in the software to do it.
    The "censoring" allows the operator of the software to provide a list of words and what they will be rendered as.
    You might have "shit" become "****", to limit the effect of poor use of language. It's actually pretty ineffective at that because people will always come up with a way to say s.h.i.t, s#it, sh1t, etc., but it is useful for other things. I'm not certain, but it may be used to transform :-) into :).
    It does the change on the fly, after any markup has been performed, so the transformation itself can't generate tags.
    Censoring /[ to [ this doesn't actually change the text, but it does change what you see. It's not an escape as such because there \ isn't a general "take what follows as literal" operator.
    (*steve*), Feb 10, 2018
    #13
  14. Harald Kapp
    FuZZ1L0G1C
    Mar 25, 2014
    268
    91
    Johannesburg North-East
    Browsing through EP's list of BB codes, the PLAIN tag may also work.
    As in this online test..
    Then enter inline[i]
    FuZZ1L0G1C, Feb 20, 2018
    #14
    (*steve*), Ian and Harald Kapp like this.
  15. Harald Kapp
    24,384
    2,416
    Well spotted!
    array[i]
    That works too, great.
    [bold][plain]array[i][/plain][/bold]
    (*steve*), Feb 20, 2018
    #15
  16. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    Oh boy, do I feel silly - the ability has been there all along! I even had a good search of the developer forums to see how to do this :eek:. Well, I've certainly learned something today :D. Good catch @FuZZ1L0G1C!
    Ian, Feb 20, 2018
    #16
  17. Harald Kapp
    Tha fios agaibh
    Aug 11, 2014
    1,650
    561
    ±μΩ I have a dumb question to ask.
    How do you enter the characters ±μΩ on the fly while typing?
    When I try to enter them they always pop up at the beginning like this (see first 3 characters).
    Tha fios agaibh, Feb 20, 2018
    #17
  18. Harald Kapp
    Ian Administrator
    Aug 23, 2006
    1,420
    371
    UK
    It should normally enter them where the cursor is (here's my test in Chrome on Windows 10: Ωμ±). If it's not doing that, I think it may be down to the browser - could you please let me know what you are using (and OS) and I'll see if I can replicate it and get it working :).
    Ian, Feb 20, 2018
    #18
  19. Harald Kapp
    8,385
    1,592
    I want to see them here: ±Ωμ - Works like a charm in Chrome under Windows 7 - µ even via keyboard (no need to access the icon, but need icons for Ω and ±).
    Harald Kapp, Feb 20, 2018
    #19
  20. Harald Kapp
    Tha fios agaibh
    Aug 11, 2014
    1,650
    561
    Ok, I though there might be a trick to it.
    I'm using a mobile phone.
    Android 4.4.2
    #20
    1. Advertisements
