A
[email protected]
I want to view EM field of a receiver, conductor is 1/2" wide, form a
loop of
about 5" x 5" square. Dielectric is 1/4" thick, Bottom layer is the
ground.
On one side (out of the 4 sides of the square) of the conductor loop,
a small gap is opened and a capacitor bridges the gap. Signal is output
from one end of this capacitor, via another capacitor:
| |-----||-----> signal
-------------------Grounding
(please use fixed width font to view the "graph")
The circuit simulation matches well with real device.
(S-parameter, etc...)
But when it copied to EMPlanner, all capacitors and the port
info are gone. And without the capacitors, the EM field is
not correct. How can this be done with any EM packages?
Ansoft Designer?, ADS?, How?
Thank you very much for help.
Apple
loop of
ground.
Apple
