elvi motor help
Dave36
Feb 25, 2017
3
Feb 25, 2017
3
Hello I am trying to build a new circuit board for my gate closer and i am reusing the old closer. My problem is that the closer uses a motor from elvi and i cant find the specs. Would anyone know where i can find the specs on the elvi 102.567 / FCE 24v WeeK 30 / 08?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Evidently that is a simple DC motor, what kind of spec's are you looking for?
M.
Bluejets
Oct 5, 2014
6,920
Oct 5, 2014
6,920
Elvi seem to specialise in dc motors.
If it has permanent magnets it will be dc.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
I need the wiring diagram. Is there any chance that the motor would be 24vac?
If it has brushes then it would appear to be DC, you can back-drive it and see if it generates a DC voltage, if it does, and if you have the RPM on the motor plate then you can extrapolate the necessary applied voltage by using a typical figure of 2000rpm max, and what the voltage would be for that RPM, this will be close to the motor rated DC.
M.
Dave36
Feb 25, 2017
3
Feb 25, 2017
3
There are 5 wires, 3 of them are smaller and connect on the end where the shaft comes out. I see that most of the elvi motors have hall effect sensors, would the 3 wires be the hall effectsensors.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Hall effect (3) sensors are usually associated with BLDC motors, which normally would have 3 stator leads and at least 3 hall conductors which would also need a reference or power.
If the one you have has two leads for the motor and the three could be a single RPM sensor, ( +V -V & sensor).
M.
