"H. R. Bob Hofmann" bravely wrote to "All" (03 Dec 03 17:59:38)
--- on the heady topic of "Re: Eliminate thermostat contact chatter"
HRBH> From:
[email protected] (H. R. Bob Hofmann)
HRBH> There are two types of bimetallic thermostats. There are the kind
HRBH> previously described here, that have or are supposed to have, a "snap
HRBH> action" to the contacts.
HRBH> The other type of thermostat is simply a bimetallic arm, without any
HRBH> "snap". This is common in acquarium heaters and other devices using
HRBH> very low-cost thermostats. Dirty contacts will make this type of
HRBH> thermostat even more likely to arc, causing RFI. A nail file or emery
HRBH> board will clean the contacts for a while, the snubbing circuit
HRBH> described by a previous poster will help reduce the arcing that seems
HRBH> to be the problem, but cannnot eliminate it entirely.
Contacts will always burn somewhat but sometimes a little is desirable,
within reason, as this will automatically burn off condensed oils and
other types of oxidation films which prevent a good contact. A snubber
will help preserve a good set of contacts but it won't help much if they
are already badly burned. Back to back diodes in series will also work
as will a spark gap (glass enclosed or other), or a VDR etc.
.... The current limits placed are based on resistance
