B
Bob Martin
I need to amplify to 2 KV complex waveforms (not pulses) in the 1-20
Hz range. Only a few milliamps are required for maintanence of an
electrostatic field.
As far as I can determine, there are three options.
1. A high voltage output transisitor from a TV. These are available up
to 5KV.
2. More commonly available lower voltage transistors and components
in a "ladder" configuration.
3. Step-up transformer wound on a special core.
The first two options have the disadvantage of requiring a HV power
supply.
The transformer, on the other hand, would be expensive unless there is
an off-the-shelf option. Size and distortion might be other detracting
features.
Can anyone advise regarding best practice for this application and
where a circuit may be found?
Bob Martin
to 5KV.
supply.
features.
Bob Martin
