Joe Bob
I'm in need of bit of help changing a small booklight from operating
with three white LEDs to one yellow or one orange LED bulb. Assuming,
it can be done, for the moment.
Why you ask. Because I have a friend who has E.P. (erythropoietic
porphyria). E.P. is an extremely rare blood disorder which makes my
friend allergic to light. Basically a vampire condition.
Whites, blues, and green bulbs are out of the question! She can
tolerate yellow and red (590nm and above) in small amounts, think 15 to
30 minutes a day, one bulb. Yes, it's that bad.
Thus, my friend has been living in almost complete darkness in a
basement now for about 8 years and she needs some help.
Trust me, I would have absolutely no reason to ever attempt this task
unless there weren't a good reason to do this. My friend is a good
person and she doesn't have anyone else who can even come close to
pulling off this task, as simple as I know the task is for someone who
is experienced.
So, back to the problem at hand. Please be patient with me, this is not
something I know proper terminologies for, etc.
She has provided me with a small booklight of her choice that has inside
it two 3 volt flat quarter sized batteries in it, and a circuit board.
I've placed some photos of the circuit board on a website of mine:
http://www.airporttools.com/led/index.html
I hope the photos help in some manner. I know they are poor, but I was
running out of light, so I had to hurry.
On the circuit board there is a switch that the user depresses once for
full brightness, twice to dim the light a bit, and three times turns the
circuit off.
Upon inspection the circuit board has three white LEDs attached. It
also has what I believe to be a capacitor whose specifications read 22uf
and 10 volts.
I do not see a resister on this circuit board which is a bit confusing
to me. Shouldn't there be one on the board?
Perhaps there is something on the board that I'm not aware of or perhaps
it's invisible BTW, I believe I know what a standard resister looks
like. I've purchased them before for a much larger lamp I built for her
previously.
Perhaps the switch is acting as a resister?
Moving on, at the battery leads to the circuit board I can measure 6
volts of current.
When the lamp is on full brightness I can measure across the leads of
one of the LEDs 3.4 volts. 3.4 volts, from what I read, may be fairly
standard for a white LED?
Eyeballing the circuit board, the three white LEDs appear to be
connected in parallel.
Anyway, basically I want to remove the three white LEDs and insert on
the board just one of the new orange LEDs that I purchased several years
ago for a similar project I did for her.
These loose orange LEDs were purchased from theledlight.com and they are
5mm 2200. I believe each orange LED bulb is basically a 2 volt bulb.
Please note that I have done enough soldering work that I believe I can
remove un-needed components and I can certainly solder on needed
components. I've done it before manually, just not on this small of a
scale. For the moment I'm going to assume I can do this task.
Now for my questions:
- Should I just give up and create a new circuit board?
If yes, then I probably can build this circuit myself. Although, I'd
rather keep the current circuit board since it already fits the
booklight's housing properly and it already has a switch built onto it
that works in the housing as well.
Assuming the answer to the above question is no:
- What role does the capacitor that's currently on the board have?
- Will I need to place a resister on the board to achieve what I want to do?
- What type of resister? Ohms and voltage please, thank you very much.
If, for example, the ohms come out to be 47 and the voltage is 1/8 volt,
can I use a 47 ohm 1/4 volt resister instead? I may have problems
obtaining a 1/8 volt resister. I can probably find 1/4 or 1/2 volt
resisters in my local stores. Otherwise, I'm may need to order some
resisters from a website?
- The measurement of 3.4 volts that I get between the leads of the first
white LED is what is throwing me off. Without a resister I don't
understand how the voltage is going from 6 at the circuit board leads to
3.4 across the first LED.
Is this what the capacitor is doing?
Or are the LEDs, in parallel, themselves creating this situation?
Or is it the switch?
Or something else?
- Can I remove the three white LEDs, then place the orange LED in the
holes where the second white LED currently sits, then place a jumper
wire between the holes where the first white LED currently sits, and
then place a jumper wire between the holes where the third white LED
currently sits?
My guess is that I cannot since 3.4 volts is what I believe to be too
much for my orange LED.
Or am I totally off base?
If there is anyone out there who would be willing to answer my questions
I would truly appreciate it. And I can assure you that your efforts
would be going ultimately towards someone who deserves a break in life.
I understand that your time is valuable, therefore, thank you so very
much for listening to me.
Regards,
Greg
is experienced.
circuit off.
and 10 volts.
previously.
volts of current.
Or something else?
currently sits?
Regards,
Greg
