Categories
Platforms
Content
need help here, anyone know what component is this?
So then..what type of this thermal fuse? Any equivalent component can replace it?
Already google it using part number..but its came out with short lead time
I don't know what you mean .... please post the link you went to
Thank kellys..appreciate your response..so..is it possible to have 2 thermal fuse in one battery pack?
no, that isn't what he said
he said the replacement ( if that original one is faulty) just needs to be the correct temperature equivalent
so have you tested it ?
if it is OK it should be short circuit, if it is faulty it will be open circuit
Bear in mind you can't solder those things into circuit - they have to be crimped to the wires.
