laurent helfer
- Sep 27, 2017
- 18
- Joined
- Sep 27, 2017
- Messages
- 18
I would like to thank you for all your answers specially hevans which is as infinite source of knowledge.
Hevans, i found a 220v motor i had from an heavy air extractor. Thats what motivate me to this project.
I found a temporar solution by cutting the 12v sourve of my 12v-220v invertor. The invertor is powering up as quickly as a atmospherical thermal engine, so it s fine for me but the invertor sometimes power up bit dont send 220v to the engine (if i give the invertor sone time between powerups it will send 220v at each time). I still want to run the invertor continuisly and the cut the 220v output but without mecanically cutting it with the gaz pedal. I still want a relay as somebody give me the idea in this forum but can't find one of these which command the 220v by simple boolean: if some 12v arrive then 220v will flow... if the 12v dont arrive (when no gaz on the pedal) then no 220v!!!! Could somebody give me a link i could find it (i found some with timer but not as i want)
Thank you!
Thank you!
