Electronic (electret?) replacement for crystal Microphone
N
nina.p20
I have several projects using the old crystal microphone.
I'd like suggestions how to change it to a more modern, electret or
cap. ones...
TIA :)
Nina
John Woodgate
I read in sci.electronics.design that nina.p20 <[email protected]>
wrote (in <[email protected]>) about
'Electronic (electret?) replacement for crystal Microphone', on Mon, 15
Aug 2005:
cap. ones...
TIA :)
Nina
Electret is best. Cheap and quite good performance. You need to add a
simple op-amp with 20 to 40 dB gain, depending on what sensitivity of
the crystal mic your project designer assumed.
Of course, you don't need to feed the op-amp output into such a high
impedance as the crystal mic needed, but there is no need to modify that
input circuit unless you want to.
N
nina.p20
Thank you very much Mr. Woodgate.
As I need to work on very small devices, I have to use discreet
components, as transistors, and I *think* that the output has to have a
very high impedance...
As I'm new to newsgroups, I don't know if it's possible to attach a
schematic...
Regards,
Nina
John Woodgate
Aug 2005:
A discrete transistor amplifier will take up a LOT more room than an
op-amp.
No, it doesn't, unless the rest of your circuit uses a rather uncommon
technique (capacitive feedback or 'charge amplifier').
schematic...
It is possible to put 'ASCII-art' diagrams on this newsgroup, but real
graphics have to be put on alt.binaries.schematics.electronics.
I think you should tell us exactly what you are trying to do. It sounds
like a project beyond your current grasp of electronics. I say that not
to insult you but to prevent you being disappointed or even running into
really serious problems.
D
Don Lancaster
cap. ones...
TIA :)
Nina
The key rule is that an electret microphone requires a dc bias.
Typically +5 volts through a 3.3K resistor.
Many thanks,
Don Lancaster
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
voice: (928)428-4073 email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
