John
I have a faulty switched mode psu. I've tested the ESR of the electrolytics
and one of them may be faulty. I have not used a cap ESR meter until now so
am not sure if the reading I am getting is indicating a good or a suspect
cap. The cap in question is a 500 Volt 33 uF and the ESR measured out of
circuit is one ohm. measuring frequency is one hundred kHz. I've read
that high voltage electrolytics have a higher ESR than low voltage ones.
Does the 1 ohm figure sound ok or suspect for this cap ? I don't have a
similar valued cap to make a comparison test.
