electonics quiz. cant figure this out can you guys help
dead civic
May 10, 2012
4
May 10, 2012
4
can you guys help me solve this problem
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
No, because you have to do your own homework to learn.
dead civic
May 10, 2012
4
May 10, 2012
4
well another way of learning seeing a problem solved. and finding were the mistake was made. but thanks for your respond anyways.
davenn
14,260
14,260
ok have moved this thread to the appropriate forum section
Hi Dead Civic
welcome to the forums :)
do you know Ohms Law ? That is the arrangement of V I and R in the triangle ?
if so use that to solve the current flow in the first question
dead civic
May 10, 2012
4
May 10, 2012
4
Hi Dead Civic
thanks. yeah I'm familiar with it. just cant figure out the formula
davenn
14,260
14,260
OK so V = I x R
now rearrange that so you can find out what I will equal :)
remember the triangle V is at the top with I and R below
with that in mind cover the one you are trying to find and see the relationship of the other two
as a hint cover V at the top and you are left with I x R on the bottom
so what happens if you cover I ?
davenn
14,260
14,260
how are you going did you see what you had when you covered I in the triangle ?
D
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
dead civic, perhaps you can tell us why you need to solve these problems.
Are you the parent of a student or something? It's almost impossible to believe that you could be a student trying to answer the questions because I would expect a glimmer of understanding by this point.
Do you know what a milliamp is compared to an amp?
Do you know what a kiloohm is in relation to an ohm?
Do you know the units used to measure voltage?
Do you know the units used to measure current?
Do you know the units used to measure resistance?
At the very least you need to know the answers to the previous 5 questions before you can even consider attempting this question.
davenn
14,260
14,260
lets wait for his response before I post anything else
I had lost my i-net connection for the last hour
now time to go home yipeee
