S
SimonLW
I put a clamp on meter on the main cable from the meter into the panel and
noticed an imbalance (should read 0). Next, I checked the ground cable going
to a water pipe and found the same current flowing. I checked the pipe from
the ground clamp side to the house and the clamp to the water main and all
the current was heading to ground.
The houses on the street are delivered power from a low voltage bus on the
poles. What I mean is each house does not have its own transformer. There is
a transformer on every other pole that is connected to the LV bus line. I'm
thinking, imbalance current on the neutral line is getting carried back to
the transformer through the water line (city water system), back up
someone's ground to the transformer since the other houses are connected on
a different part of the bus. Does this make sense? Is that excessive
current? Should the utility check it?
