Actually you can simply try and discover the correct position to match the writing on the case.
The switch is a 360 degrees rotatory one,turn it and try to find the diode/continuity position.
Do this:
Insert test leads and short them permanently together.
Rotate the switch till you hear the continuity beep sound.
Congratulations your meter is oriented.
