Display Lens Source
Discussion in 'LEDs and Optoelectronics' started by alfa88, Jul 3, 2018.
  1. alfa88
    alfa88
    Dec 1, 2010
    323
    4
    Hawaii
    I've been restoring some old equipment and run into a brick wall trying to replace the damaged front panel display window. One meter uses Nixie displays and has an amber colored window, the other uses a 7 segment led display and would need a red tint. The thickness should be ~ 0.9mm/.035" . I tried a spray tint on some vinyl page dividers obtained at a office supply store but not only did the paint adhere poorly; the clarity was miserable . Tried milling down 1/8" tinted acrylic with a Dremel. Fail. And lastly investigated several suppliers of gel filters but can't seem to get an answer on the thickness. I'm hoping there's a brainiac that knows of a source.
    alfa88, Jul 3, 2018
    #1
    1. Advertisements
  2. alfa88
    8,371
    1,585
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Harald Kapp, Jul 4, 2018
    #2
    1. Advertisements
  3. alfa88
    KJ6EAD
    Aug 13, 2011
    1,066
    141
    Earth
    KJ6EAD, Jul 4, 2018
    #3
  4. alfa88
    Externet
    Aug 24, 2009
    531
    111
    Mideast US
    Look for clear-colored plastic 'dividers' for folders at the office supply place.
    [​IMG]
    Or, If you find the wanted thickness in clear acrylic/plexiglas, mix fountain pen ink with clear coat and spray.
    Externet, Jul 5, 2018
    #4
    davenn likes this.
  5. alfa88
    alfa88
    Dec 1, 2010
    323
    4
    Hawaii
    I found paint or dyes not to durable.
    I looked up polyester and sure enough Granger has something that will work.
    I guess I just associated polyester with Saturday Night Fever
    alfa88, Jul 5, 2018
    #5
    hevans1944 likes this.
    1. Advertisements
