I have a circuit as illustrated in the attached image.
the 3 positions on the 3 position switch are:
1 - off,
2 - continuity test with LED, and
3 - full current to the appliance when momentary switch is pressed.
The second position is used to indicates that the circuit is complete, but pressing the momentary switch will not allow full current to the appliance.
This is what I want in position 2.
The third position allows me to press the momentary switch to provide full current to the appliance, but currently, in position 3, I lose the LED indicator unless I close the spst switch.
I would like to eliminate the SPST switch.
So my desired result in position 3 is for the LED to still be lit, and pushing the momentary switch will provide current to the appliance without having to use the spst switch.
I was thinking I could replace the switch with a diode, but I am having trouble figuring out what type/size diode to use.
If anyone could let me know what I can can do to accomplish what I'm tryng to accomplish, or point me to a location where I can find the answer, I would appreciate it.
1 - off,
