Dimming compass, stereo etc on Sea Ray boat
M
Marc Heusser
I find some of the lights on a Sea Ray boat (2006), SmartCraft
instruments etc rather annoyingly bright in the night, especially the
Compass and the stereo remote control.
How can I dim them further, and possibly change the blue (!)
illumination to another color? Has anyone modified it to use LEDs, eg
red or green instead of the dreadful blue?
TIA
Marc
B
Bruce in Alaska
TIA
Marc
The "Age Old Solution" to your problem is to change the Lights to
RED colored Light Souces, which will illuminate the instruments,
but not effect your Night Vision. This is what happens when
Designers, design products for a Markket they havee no experience or
understanding of. Blue Light is the absolute Worst color for Night
Vision type operations.
Bruce in alaska
S
Steve Lusardi
Marc,
Please also note that the conventional solution of adding an adjustable
resister in series for dimming the light will not work with leds, as the
voltage to drive the led is quite specific and is different for each
available color. The correct way to dim leds is change the duty cycle with a
chopper, like a motor control for a PM motor. Of course, that method also
works with conventional filiment lamps as well.
Steve
M
Marc Heusser
Steve Lusardi said:
Marc,
Bruce in alaska
Steve and Bruce
the series resistor works of course. The LED's need 2 to 3.5 V
(depending on color etc), the difference to 12 V just heats the resistor
that is usually used as a good enough current source. The light is very
proportional to current flowing through the LED.
PWM is just an energy saving way of dimming. This is most likely what is
already provided.
I found the Compass to be illuminated by a conventional 3mm LED with
series resistors. I'll replace it with a red/orange one and appropriate
resistors.
To continue Bruce's thoughts: It will be best to use red LED's of around
610 nm wavelength (actually usually called orange), since the dark red
ones at 680 to 700 nm emit light that many people are very poor at
seeing. That is why aircraft and ship lights have to be of the 610 nm
wavelength.
(see http:
//www.periheliondesign.com/downloads/redandgreenledpositionlights.pdf)
Now I just have to find how to dissassemble the SmartCraft Speedometer
etc to replace the white lights (hopefully standard LED's) with red ones.
As for the remote control of the stereo, I'll probably just use a grey
filter to stick on.
Thank you for the ideas.
Marc
W
WaIIy
TIA
Marc
SeaRay sells a very nice dimmer. I had the same issue on my 89
Sundancer.
As I recall, it wasn't super-cheap, but less than $50.00
rpr
Aug 15, 2009
Aug 15, 2009
Old post, but I am trying to figure out how to INCREASE the display brightness of my SmartCraft gauges. I can barely read them in sunlight.
Any help?
