Dimmable led drivers?
Discussion in 'LEDs and Optoelectronics' started by primuspaul, Feb 13, 2018.
  1. primuspaul
    primuspaul
    Feb 7, 2018
    53
    #1
    1. Advertisements
  2. primuspaul
    8,184
    1,525
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    This kind of dimmable LED driver is meant to be used with a classic dimmer/switch combo used to control brightness of lamps. The featiure "dimmable" needs to be mentioned since not every LED driver will work with this kind of dimmer.
    For setting the brightness on the low voltage side via potentiometer or similar typically a technique called PWM is used. You can buy off the shelf modules for that purpose.
    Harald Kapp, Feb 13, 2018
    #2
    1. Advertisements
  3. primuspaul
    primuspaul
    Feb 7, 2018
    53
    What if I want to use the dimming module to permanently dim the LED? Do I need a resistor on live 120VAC wire? Is there a cheap way to do it without generating waste heat?
    primuspaul, Feb 14, 2018
    #3
  4. primuspaul
    Bluejets
    Oct 5, 2014
    2,434
    474
    Phase control dimming waste heat would be hardly detectable.
    Bluejets, Feb 14, 2018
    #4
  5. primuspaul
    8,184
    1,525
    A resistor is a cheap way to generate as much waste heat as possible.
    Use one of the PWM modules I linked.
    Harald Kapp, Feb 14, 2018
    #5
  6. primuspaul
    Sunnysky
    Jul 15, 2016
    454
    109
    Toronto, Ontario
    This LED driver is NOT meant to be dimmable without issues. It provides a CC output of 300mA +/-3% with TOO WIDE an input range for triac dimming to be practical. max/min =265Vac / 85Vac is 3.4x ratio so the output will track and stay constant over this RMS voltage ratio. So when you want to dim it with an input < 85V it will start saturating the buck coil with more current and it will start making noises (buzz) try to put out max current with low input voltage. Remember it was design to put out constant current,. SO bad choice for a dimmer. upload_2018-3-14_15-47-8.png
    Sunnysky, Mar 14, 2018
    #6
  7. primuspaul
    Bluejets
    Oct 5, 2014
    2,434
    474
    Note that there are many types of lamp dimmers and most are for a specific purpose and as such most will not work correctly with LED dimmable drivers.
    Bluejets, Mar 14, 2018
    #7
    1. Advertisements
