B
[email protected]
hey,
i'm looking for an oscilloscope for audio applications, preferably
digital, so i'm not looking for a huge bandwidth
so i'm looking at the instek gds-806s and similar models,
anyhoo, i have a question about the vertical resolution
it states the vartical resolution is 8 bit, and the vertical
sensitivity is 2mV/Div to 5 V/Div
my question is where typically is the DAC located?
is it after the vertical sensitivity switch in which case at 2 mV /
div i would expect a resolution of
(2mV / DIV )* (no of div) / 2^8 = 0.008 mV * no of div = 0.08 mv with
10 div
similarly at 5 V /div i would expect resolution to be
5/ 256 * no divs =0.2 volts with 10 divs
or is the DAC located before the vertical sensitivty in which case the
resolution is always the same regardless of vertical resolution
setting?
i read that for audio purposes, 16 bit minimum is necessary. Is this
true?
also if anyone could recommend a decent oscope for audio purposes
please let me know. i'd consider a PC / soundcard unit but would rather
a stand alone digital unit.
Tom
10 div
setting?
true?
Tom
