Greetings folks..
Since Jim has probably already made his selection, this reply are
for all the folks reading this that would like to see the various
feature options on the Coupon-Eligible Converter Boxes (CECB).
http://en.wikipedia.org/wiki/Comparison_of_CECB_units
Keeping in mind that your options are few and the exotic features
are just not to be found on a government subsidized program,
these boxes (in general) perform their conversion function and
not much more.
I have both the Zenith DTT-901 and the Digital Stream DTX-9950
both of which are fine units. The Electronic Program Guide (EPG)
on the 9950 will allow up to 3 days of TV Guide like listings of
upcoming programming while the Zenith only shows 2 hours (now and
next). Beyond that, the aspect ratio on the Zenith is memorized
for each and every channel individually (quite nice!) while
(unfortunately) the 9950 has one (1) aspect ratio setting for ALL
your channel received and memorized. Therefore, you can not set
one channel's aspect ratio and have another with a different
aspect ratio. Not a big deal - just a bit nagging when you come
across a channel where the "zoom" or aspect ratio must be changed
for a 4:3 conventional CRT based television then you later change
channels to another that needs the original aspect ratio.
Cheers,
Mr. Mentor
If within the U.S. the following will get you coupon until which
time the program ceases or funds are extinguished -
https://www.dtv2009.gov/
| Jim Yanik wrote:
| > your $40 coupons are only good for a limited time.
| > the DTV converter everybody is waiting for is the Echostar
TR-40,due out in
| > June or July,last I heard.
| OK, I finally have my coupons, is the Echostar TR-40 (CRA)
still a good
| choice? I see different ratings and they go from very poor to
very
| good. I understand Dish Network bought them and I think added
the
| analog pass through, not quite sure. It does sound like you
can buy the
| same item but pay more if Dish Network put their name on it.
| The one thing I may want to have is a smart antenna and I don't
believe
| the TR-40 has that. That is a tough call though, I won't know
if I need
| a smart antenna until after I get a converter and see how it
works. I
| suppose I could get 1 of the Magnavox at WalMart and see how it
does?
| Open to suggestions........
| Tony
