Difference between an optocoupler and a SSR
M
mbattistello
Does anybody know the difference between an optocoupler and a Solid
State Relay?
Thank you very much!
Kind Regards,
Matías
KMoffett
Jan 21, 2009
723
Jan 21, 2009
723
Opto-couplers are "generally" designed to transfer and isolate lower power signals.
SSR's are "generally" designed to allow lower power signals to be isolated from, and switch high power devices.
Ken
S
Sjouke Burry
State Relay?
Kind Regards,
Matías
The last one is a special version of the first one.
Jamie
State Relay?
Kind Regards,
Matías
Why should there be a difference? most that I know of integrate a
opto-coupler for isolated control of the solid state switch.
In other words, consider a SSR having a optocoupler in it.
http://webpages.charter.net/jamie_5"
E
Eeyore
State Relay?
An SSR typically carries heavy loads and likely incorporates an
optocoupler and possibly also zero-voltage / current switching
circuitry.
An optocoupler is a low power device designed simply to galvanically
isolate a control input and output.
Graham
