Did I get shocked by my TV power supply?
Discussion in 'Troubleshooting and Repair' started by Dasitmane, Dec 6, 2016.
  1. Dasitmane
    Dasitmane
    Feb 26, 2016
    4
    I was replacing a power supply on a 50 inch LCD tv and had nitrile gloves on and accidentally bumped a cap and transistor and felt a strange feeling in my abdomen, but no shock like symptoms that you would typically expect, it was very quite and slightly stinging, but not in my arms or anything just a spot in my abdomen. Is there a chance that you can get shocked but not have the classical feeling of getting shocked, in say maybe higher frequencies?
    I uploaded exactly what I bumped. The nitrile gloves that I was wearing were just throw aways. i didn't think anything of it at the time but afterwords ive been having a lot of anxiety and just feel strange all together..
    The tv and power supply was unplugged at the time, but I had powered it up minutes before to check its function before removal.
    #1
    1. Advertisements
  2. Dasitmane
    Neal
    Dec 23, 2009
    23
    12
    Dayton, NV
    That's what is called having a gut feeling;)
    Neal, Dec 6, 2016
    #2
    Harald Kapp likes this.
    1. Advertisements
  3. Dasitmane
    73's de Edd
    Aug 21, 2015
    2,230
    736
    Texas
    Or . . . . .Installation anxiety
    73's de Edd, Dec 6, 2016
    #3
  4. Dasitmane
    8,304
    1,563
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    It's not unusual to get a shock from high voltage equipment shortly after disconnecting it from mains as charge is stored on capacitors and is dissipated only slowly. A so called 'bleeder' resistor is used to discharge the capacitors, however the discharge current is very small so it doesn't disturb the normal operation of the circuit, therefore it can take quite some time until full discharge.
    This effect has nothing to do with high frequencies.
    Harald Kapp, Dec 6, 2016
    #4
  5. Dasitmane
    chopnhack
    Apr 28, 2014
    1,570
    346
    Florida, USA
    This time of year, I would expect you to be wearing a shirt while working so there is a good chance your stomach was insulated. That being said, not likely related. Have you been under a lot of stress lately? It could very well be medical related like mentioned before, anxiety.
    chopnhack, Dec 6, 2016
    #5
    HellasTechn likes this.
  6. Dasitmane
    Maxwell
    Oct 1, 2016
    47
    I've heard of people being sick after an electric jolt. Symptoms are akin to a stomach bug like sickness, feeling weak, vomiting, cramps.
    If you're unsure, just see a GP.
    Maxwell, Jan 7, 2017
    #6
  7. Dasitmane
    hevans1944 Hop - AC8NS
    Jun 21, 2012
    3,729
    1,790
    Venice, Florida, USA
    This may just be your sub-conscious telling you to quit messin' around with electronics...
    hevans1944, Jan 7, 2017
    #7
    Arouse1973 likes this.
  8. Dasitmane
    alfa88
    Dec 1, 2010
    321
    3
    Hawaii
    I wouldn't trust latex or nitrile gloves for electrical work. I've observed that the touchpad on my laptop will still respond while wearing them. Probably a capacitive property but sweat and oils can only add to the mix.
    alfa88, Jan 7, 2017
    #8
    1. Advertisements
