Hello.
This is a circuit(Sziklai pair)that amplified a small current by a germanium and silicon transistor in order to turn on a led.
The germanium transistor has a collector base leakage(Icbo),which is amplified twice and cause the led to turn on even when the base of the germanium doesn't get signal.
In order to find what is the Icbo of the germanium through the datasheet,i need to know the Ucbo of the germanium transistor.
Those are the parameters in the datasheet.
Ucbo=0.5V--------->Icbo<=10uA(25°C)
Ucbo=10V---------->Icbo<=14uA(25°C)
Ucbo=32V---------->Icbo<=500uA(25°C)
So,what is the Ucbo of the germanium transistor,refer to the attached circuit,and how do you come to that value?
2)When this small leakage current flows,initially,through the circuit,before it is amplified(red arrows in the attached circuit),what should be the voltage drop on the led,the resistor and the silicon transistor emitter-base?
Thanks in advance.
Thanks in advance.
