Designing Schematics for inverting 741 OPAMP
citro250
Jan 21, 2014
Jan 21, 2014
doing a little home project here for an opamp my cousin tells me I can make one with these components but I need to design the schematics, he tells me I can't do it but I think you can!
help me out! :D:eek::cool:
Single ended supply
Power supply 9V dc at 10mA
Output impedance: 1kΩ
Input impedance: 2.2kΩ
Adjustable output level: max 40dB variable resistor, potentiometer
Frequency range: 20Hz to 20kHz +/-3dB
Max input signal 40mV
Max amplifier gain = 100
It is to use a 741 op-amp in the inverting mode on a single power supply built on Vero- board
Components given, parts list:
Resistors:
2.2kΩ
22kΩ ×2
220kΩ
RV1 1kΩ
Capacitors:
1µF ×2
10µF
IC
741 OP-AMP
Harald Kapp
13,719
13,719
Here are single supply opamp circuits you can use with the 741.
By the way I do think your cousin is really your teacher and this belongs in the homework section.
7,682
7,682
The GBP of a 741 is 1MHz, so the gain at 20KHz will be 50, not meeting your spec. Also the 741 is a very bad choice for single supply operation.
Harald Kapp
13,719
13,719
Bob is right, the 741 is quite a bit outdated and doesn't meet the specs.
But: -3dB at 20kHz is equivalent to a gain of 0.707 (compared to 0dB, where gain=1). Therefore max. gain of the opamp circuit in the passband (f <<20kHz) can be up to 70 (50/0.707) - still not the 100 required.
You can design the circuit for a max. gain of 100, but then the attenuation at 20kHz will be -6dB which is a violation of another requirement.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Well, it does specify the maximum gain.
Designing an amplifier with a lower gain still meets the spec <evil grin>
