Sorry about your endoscope. I hope you get it figured out soon, or at least have a plan "B" such as a powerful mirror.
When you do get to sifting through all the plocketry, (a Michaelism?) you may have to just trust your own intuition.
Prints and forum correspondings be damned.
If you know you have it at X and not Y, you'll just have to get in there and methodically follow the circuit. Use a Sharpy tip marker to keep track of where you are on the traces.
The Gnd path can be confusing, but its merely a daisy chain you have to follow.
Thanks for the encouragement, John. These endoscopes are inexpensive - say about $12. so I have a replacement on order. There's no room in there for any mirror - the HDMI and AV_B'D's being so close to each other - so I have come up with, as you say, a Plan 'B'. It is simple. I have followed the Audio Path and documented the IC's through which that path goes. It looks like this: (1)IC30 (16pin) Page126 HDMI Component Side : [DA+5V] pin6-7&14-15 [DAGND] then I extracted similar DATA for (2)IC21,(3)IC22,(4)U8,(5)IC29,(6)IC28 A&B,(7)IC801. On each IC I have stuck a very small square of label paper and written the IC's I.D. My instructions to myself are: "Now DVM continuity tests can commence. In strict order." These Tests are Continuity between each IC Power and GND pin and the source of that Power or GND on that PCB. Following this will be the Plocketry Test - where, with the 'Stack' built on the Bench in the Lab I can confirm continuity between all Plockets. (a plocket, in this case being, of course, the interconnecting CN/CP - or whatever). But before that we are off to a Concert in an ex-Church (Saxon in origin with Regency additions) in which, about 30years ago I gathered a team together and, in true Community Spirit, dismantled, documented, repaired, re-engineered and rebuilt, in a new position, a 100 year old Two Manual William Hill Pipe Organ. In the Opening Recital, under the aegis of the Carnegie Trust, it was played by Dr.Francis Jackson, Organist of York Minster. The Concert this morning is Strings and Oboe only - but the group are coming to the end of their Annual Festival, and one of their Members is an Organist - so I want to introduce them to the Organ for future inclusion in, say, next Year's "Lewes Chamber Music Festival". (Look it up on Internet) "Plocketry" Yes - it answers the requirement for a generic name I think. Michael Studio1 UK 09:07BST 16-06-2018
