Categories
Platforms
Content
You mean John? (Tha fios agaibh?)I don't know - but he comes on quite frequently. Without both of you and the occasional 73's de Edd, I would not have got anywhere.Now we're out of my depth. Where's the green tree monster?
Thanks, Bushtech. Well done for finding them - what gave you the inspiration? I shall obviously have to spend more time mastering the layout of the Service Manual. How C513, ( on FR Channel) C514, ( on SL Channel) C515 ( on FL Channel) which are on the 7CH.AMP B'D come to be on the Cct.Diag of the HDMI B'D. is beyond me - Poetic licence? Then there is this business of the information about these three Caps.[AVR 1712 ONLY OPEN] - how is this to be interpreted? I can only think that - with the three caps actually on the 7CH AMP B'D, this information only applies to the 1712 model - and that 'OPEN' indicates 'not there'. Michael Studio1 UK 17:20GMTOk
C515 on pg 120 of 196, bottom left hand corner. Look at ref line A to O at the bottom of page. Between C and D, right above the division between them.
Hi folks, the green treemonster and wife has escaped the cold habitat to Mexico for a week.
Michael, i see your progressing fine with some help from bushtech.
I can't offer much help at the moment but keep tinkering and you will have more of those "ah ha" moments.
I will pop in when i can to see your progress.
Audios amigos.
I noticed that the caps are numbered more or less consecutively on a page eg. C6XX will be on the same page.
I think you're right with the 1712 inference, but to find out why they are there we need to figure out where something like "To Digital Connect" leads us
I have managed to find C515 on the wiring diagrams pg104 just to the left of IC15. Hope that helps.
Thanks, Bushtech. I think you have uncovered a whole new can 'o worms here! The one on Page104/6F isn't the C515 we're interested in - which is physically adjacent to the top two pins of CN404 Page93/D2. Maybe we should sub-divide these references by 1/10 to give a closer hit? = Page93/D0.3x2.2 - it's actually etched on the PCB of Channel FL C515 just below the + leg. This is the 2nd double-entry in the AVR-1912E2/EA I have come across. The other is in the Parts List Page177 and Page182 - there are two IC-102. Anything is possible here! You'll also find that Page 168 refers to an IC801 - the pins of which bear little resemblance to the IC801 on Page114. even though the numbers ascribed to both are identical. More food for thought. I'm just off to Brighton-on-Sea (about 10 miles away) so I'll check for comments on my return. Michael Studio1 UK10:12GMTPage 104/6F
Hmm. Sloppy design work by Denon or purposely obfuscatory? Whichever, I'm out of my depth here, need somebody who can make sense of this
They are duplicate cap numbers.caps: C512, C513, C514, C515 on Part List Page193 are not electrolytic.) So there is something strange going on here. Anyone think of an answer? The other important thing is to discover the reason Q464, Q470 and Q469 along with their associated R640, R641, R646, R647 (all 2WJ-0.47Ω.)
For instance C513 is a electrolytic on page 106, But there's also a C513 ceramic cap on page 120. I wouldn't read too much into it, just use what the circuit diagram shows and use the parts list as a reference.
Hard to say what caused your transistors to fail, but obviously if one shorted, any components in the path would not enjoy being spiked with the full current the power rail could deliver.
Thanks Michael, we're having a great time in the warm weather. I guess down here "warm" means 95F (35c) Back home, we call that Hot.
Yes, component can just short out out for no apparent reason, but from my limited experience, The components that usually lead to their demise are things like capacitors and diodes that play an important role of keeping the circuit working as it was intended.
For instance if a capacitor is starting to go bad, it's lowed capacitance causes the impedance and frequency response of the circuit to change. A diode leaking or improperly working can also be a big problem.
When you shorted out the testpoints (to each other) it wouldn't hurt the circuit because it's almost a short circuit as it is.
It would only change the resistance a fraction of an ohm.
Whatever happened that caused the voltage rail to go astray may have been where things went wrong? Idk.
Stay vigilant, and be as thorough in checking for bad components as you can.
How do you pronounce 'Scones'? - to rhyme with . . . ?Thanks bushtech, I thought for a moment Michael was talking about Tea and scones.
Lol
