Delay off delay circuit
remzy
Jun 12, 2015
47
Jun 12, 2015
47
Hello everyone. I want to make a delay off circuit to use in my car's dome light because right now it turns off when I close the door and I want it to stay on for about 15 seconds after I close the door. I found a circuit which works but the problem is that it is activated by a positive voltage, and there is no way to activate it because my car's door switch switches a negative voltage, i think they've done it that way because they only need one wire to dome light instead of two if it was switching positive voltage. Is there a way to activate this circuit with a negative signal-voltage? Here is the circuit:
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
A 555 Timer will trigger on the negative going edge and provides enough drive current to drive a small relay coil.
However, before you go through the work of brewing your own check out Ebay under "Delay Timers". The Chinese can sell you a complete timer with 'on board relay' for less than you could make it yourself.
Chris
73's de Edd
Aug 21, 2015
3,613
Aug 21, 2015
3,613
Sir remzy . . . . .
If your vehicle is using the typical dome light circuitry shown, which uses a grounding switch in each door . . .then . . .the second circuit using 9 common parts should give an all solid state solution.
In final evaluating, if more delay time before dimming is needed increase the circled capacitors value.
Le Schematique . . . . .
73's de Edd
remzy
Jun 12, 2015
47
Jun 12, 2015
47
Sir remzy . . . . .
73's de Edd
Thanks for the circuit. I will try it out. There might be issues because I've modified my dome light from incandescent bulb to LED's.
73's de Edd
Aug 21, 2015
3,613
Aug 21, 2015
3,613
Sir remzy . . . . .
Should be no problem, if about the same or EXPECTEDLY pulling much less power consumption, the T2 "electronic switch" should then be able to loaf.
73's de Edd
