DDR3 SODIMM socket?
Discussion in 'Electrical Engineering' started by DaveC, Aug 8, 2013.
  1. DaveC
    DaveC Guest
    I need one of these:
    http://tinyurl.com/lzvf2hw
    It's a low-profile smd type DDR3 SODIMM socket for laptop use with those
    little metal spring-release tabs.
    I need one with 4 mm total height. All the ones I can find are 5-plus mm.
    I've seen 4 mm parts in manufacturer datasheets but can't find any US
    distributors.
    And it needs to be standard orientation flavor (key right-of-center, relative
    to user's view when inserting the SODIMM).
    That last point is glossed-over pretty easily by even product drawings: as
    far as I can determine these come in both orientations: the two types are
    identical except that the polarity key is right- or left-of center. I think
    the "standard" model is right-of-center key.
    Mouser has only vertical orientation sockets (a la desktop motherboard).
    Digi-Key has the correct type but wrong key location (reverse style).
    Sources?
    Thanks.
    DaveC, Aug 8, 2013
    #1
    1. Advertisements
    >distributors.
    >Sources?
    >Thanks.
    Maybe the 4mm guys were 'lying', and re-fashioned their spec sheets.
    Could you not get a set of those as a reference element?
    DecadentLinuxUserNumeroUno, Aug 9, 2013
    #2
    1. Advertisements
  3. DaveC
    DaveC Guest
    I have one 4mm socket, removed from a mboard -- wrong "sex" (key located
    wrongly for my needs). Labeled
    "DDR3 1.5V 4.0R" with logo "LCN"
    http://www.lionconn.com.tw/
    but I can find no distributors for this.
    DaveC, Aug 9, 2013
    #3
  4. DaveC
    DaveC Guest
    > This might work:
    > http://www.digikey.com/product-detail/en/78194-0001/WM19149-ND/2046762
    > Digikey does not stock but they say minimum order is 1. Standard package
    > is 16 so you might have to buy 16. I have ordered different non-stock
    > connectors from Digikey with no problems. Wanted 10 for a special
    > project. Got it in 3 weeks.
    That does look good.
    It's now obsoleted by Molex but Digi-Key crossed it to this TE part:
    http://www.digikey.com/product-detail/en/2-2013022-2/A111119CT-ND/4142503
    and it will work for me.
    Thanks for the pointer.
    Have a great weekend.
    DaveC, Aug 9, 2013
    #4
    Probably cheaper to buy a dead version of the entire motherboard, and
    salvage one (or more) from that.
    #5
    1. Advertisements
