[email protected]
I have 20V PV solar panel.
I want to charge 12V automotive battery.
I would like to hack apart some electronics
and make a DC/DC converter so I can charge
the battery.
Any ideas on how to ? I was thinking of
tapping into a PC power supply after the
rectifier, and using the supply to convert
20V DC into 12V DC?
This is going in a VW camper van. I have
a few spare voltage regulators from the VW.
It looks like the VW voltage regulator
works by varying the voltage
to the "field" coil in the alternator. If
the output voltage from the alternator is
too great, it reduces voltage to the field
coil. If the voltage from the alternator is
too small, it increases voltage to the field
coil.
So, the regulator has
1)V+ input (this voltage is output from alternator)
2)V+ output (for field coil input on alternator)
3)ground
4)V+ output (to battery to be charged)
would there be a way to use this scheme to
control how many volts get to the battery?
I was thinking of maybe a variable resistor
that can be controlled by an analog input
voltage. Mimic the field coil/ alternator
with another device.
There is no coil in the solar panel.
I have "constant" voltage output from
it.
The regulator increases one of it's outputs
(output to field coil in alternator)
if the power input is too low.
the regulator decreases the output
if the power input is too high.
How to regulate +20v from PV panel with this
inverse proportional analog voltage?
Jen
the battery.
20V DC into 12V DC?
coil.
3)ground
it.
Jen
