TomJames999
- Dec 7, 2014
- 4
- Joined
- Dec 7, 2014
- Messages
- 4
Evening guys,
I finally got my Voltage regulators from China which I thought to be the main issue unfortunately the motor control unit still doesn't work.
Background: The remote switch have stopped working, change of the battery didn't help either so I've just just the Manual Switch on the box. Decided to add remote momentary push button which didn't work (possibly wrong connections and I might have Short circuited something) so I took it off and kept using the Manual Switch.
After period of time the LED indicated (small red led at the left bottom corner) indicated that the circuit have power supplied however the button didn't work any more.
I took my Multimeter to measure the following:
I took the PCB off and checked the switch, there is continuity across switch, the main Bulb, 5W resistor (which i placed under bulb), across Closed contacts of voltage relays which all works fine.
Where should I be looking further for broken part?
Circuit:
Circuit explained to what I know:
http://s17.postimg.org/qlg09wprj/20150411_183418.jpg
Cheers,
Tom
edit: I just found something strange, the Big relay shows that Terminal 1 and 2 are NC, so I go a multimeter across them and they seems to be Open while Terminal 3 and 4 are NO but there is continuity across them.
- Voltage across DC Bridge: 26V
- Voltage across Voltage Regulator: 30V
Circuit:
Cheers,
Tom
