BlackMelon
- Aug 7, 2012
- 188
- Joined
- Aug 7, 2012
- Messages
- 188
Hello,
I do a simulation on the attached schematic. The input is 12-0V square wave with 50% duty cycle at f=8kHz. I want to know the Q1's collector current waveform, so I connect R3 = 1 ohm, and measure the voltage across it. As you can see, when the input is 12V, V+ - V- = 450mV. This means there is a current from the left pin of R3 to the right pin.
My question:
When Vin =12V, does this mean the current of Q1 flow from emitter to collector? If so, why does the NPN transistor carry such a current?
Thank You
BlackMelon
My question:
Thank You
BlackMelon
