Braeden Hamson
- Feb 18, 2016
- 240
- Joined
- Feb 18, 2016
- Messages
- 240
I've been looking all over for a schematic for a good power supply, but I'm not having any luck finding one that doesn't use a voltage regulator IC. Those are inefficient and I'd like to avoid them. People on this forum as well as elsewhere recommend a buck/boost converter for the voltage portion.
However I haven't been able to nail down the current limiting section. A quick aside, as I understand it a CC/CV power supply is has a CC section and a CV section, they're never both running. One gets selected when by a controller when the current exceeds a set limit or when the voltage exceeds a set limit. And they're selected with a kind of switch. Back to the main topic. Again I can't find a current limiter that doesn't use a regulator IC. Whats a good way to regulate it? Can I just use another buck converter? Or am I wrong in my understanding that a current limiter is a voltage regulating type circuit in which a controller measures the current and adjusts the voltage accordingly.
Wonder if I could get my hands on a Keithley PS diagram.
