Tooting their own horn, but this is the meat from their press release:
"Cree's tests confirmed that the 1mm x 1mm LED produced 173 lumens of light
output and achieved 161 lumens per watt efficacy at a color temperature of
4689K. The tests were conducted under standard LED test conditions at a
drive current of 350mA, at room temperature."
Eefficiency is interesting, but more so at that color temp. Most effecient
LEDs are cool white.
It has generally been the case that cooler white LEDs (CCT 5000-6500 K)
had greatest overall luminous efficacy.
However, that is theoretically increased by adding more phosphor to
convert more of the blue light to yellowish light, despite the Stokes
loss. Why it usually does not?
1. The phosphor may absorb some of the yellowish light, so that may limit
the amount of phosphor that can be added before overall luminous efficacy
starts decreasing.
2. Adding more phosphor can make the overall color more green than
blackbody. Adding a more reddish phosphor will decrease luminous efficacy
compared to a less reddish phosphor.
However, it still appears to me that if the phosphor does not absorb its
own output, overall luminous efficacy should increase as CCT decreases
towards maybe 4,000 K or upper 3900's K or so.
The lower CCT may be a sign that phosphors are being developed that
absorb less of their own output.
Another consideration: When Osram issued a press release on its high
efficiency laboratory prototype power LED, the CCT was 5000 K. Also
notable was that the cromaticity was greenish.
http://www.ledsmagazine.com/news/5/7/22
A combination of red/reddish LEDs and yellowish-whitish ones greener
than blackbody is described in US Patent 7,213,940, owned by what is now
Cree Lighting. My guess is that their LR-4 and LR-6 fixtures use this.
So I wonder if this latest Cree laboratory prototype with lowish CCT is
more green than blackbody? If so, I suspect that more efficient LED
lighting fixtures based on US Patent 7,213,940 will be in the pipeline.
- Don Klipstein (
[email protected])
