CPL Load analysis
Discussion in 'General Electronics Discussion' started by Anmol S, Aug 22, 2017.
  1. Anmol S
    Anmol S
    Aug 22, 2017
    I wanted to understand the effect of CPL on a Power supply component like SMPS or LDO (May be to cascade the them and load CPL at end),for that I wanted to model CPL to analyse small signal stability ,can you give me suggestion regarding modelling .This will be very helpful.I have TINA TI SPICE
    I want to do stability analysis of buck CPL load system and hence to determine their close loop performance.& stabilityt then I need to design controller for this
    #1
    1. Advertisements
  2. Anmol S
    kellys_eye
    Jun 25, 2010
    2,456
    630
    West Coast, Scotland
    Much as modern active load circuitry I suppose....
    MOSFET load (power dissipation) device(s) with source current sense resistor generating feedback signal to comparator with set-point voltage (load) determination. You could chuck in temperature compensation if necessary.
    kellys_eye, Aug 22, 2017
    #2
    1. Advertisements
