Countdown Timer with Alarm Trigger
Discussion in 'General Electronics Discussion' started by tsibia, Sep 14, 2018.
  1. tsibia
    tsibia
    Sep 14, 2018
    I need to provide a countdown timer with a big wireless button for a disabled person.
    - The countdown timer must countdown from pre-set 15 minutes and be started by a wireless push button.
    - At zero minutes, it must be able to trigger an external alarm or bell for 15 seconds, unless acknowledged earlier
    - The timer should then reset awaiting the next same event.
    Only the trigger button has to be wireless.
    It is to be used by disabled people when alerting carers for providing on-call assistance at pre-set intervals.
    Kindly assist
    #1
  2. tsibia
    7,325
    1,538
    Worcester, MA
    I am finding it difficult to understand what you are asking for. It sounds like you are saying you push the button, then it waits 15 minutes and then activates an alarm? This does not make a lot of sense, what if help is needed immediately? Or are you saying something different?
    BobK, Sep 15, 2018
    #2
  3. tsibia
    AnalogKid
    Jun 10, 2015
    2,208
    623
    Ohio - GMT-5
    This can be done with a CD4060 as the timing generator and a few small signal diodes to decode the output state, inhibit, and reset.
    ak
    AnalogKid, Sep 15, 2018
    #3
