B
[email protected]
Hi
I'm not about to buy these, so theres no point asking suppliers, but I
need to get a rough idea of likely costs of some kit. It would consist
of a GPS receiver to work out where it is, some kind of simple procesor
to work out which direction it wants to go in to reach its target
destination, using a simplified map to avoid a limited number of
impassable obstacles. It will need a small solar panel and battery for
power, and include a few beefy solenoids that it switches on and off at
upto 1Hz.
It also needs a connector (or rf receiver) so external target
coordinates can be given to it with an external device.
Equipment life need not be very long, as the kit will be destroyed
after typically around a year. So if 99% make it to 1 year that would
be acceptable. Module repair or maintenance will probably not be an
option.
This lot would be made in volumes of 1,000,000 ish...
Where do I even start costing this lot up? No, I dont have a cirtcuit
design, nor am I about to build them. At this point just need to get a
rough handle on cost to know if an idae's worth continuing with.
thanks, NT
upto 1Hz.
option.
thanks, NT
