Hi All,
I hope you clever people can help me with my problem,
On my car I changed the clutch fan with an electric one,
the fan is wired through a 40Amps Relay, everything works ok for a while
then the fuse just melts away! I used fuses as high as 30Amps!
The fan motor is ok, the relay has been changed twice, all wiring looks good,
what is causing the failure? how can I remedy the situation?
thanks for your help
