O
[email protected]
Hi, i have a square signal, with positive at 15V, and negative with
-15V, and i will like to convert this signal so that 15V will be 15V,
and the -15V will be 0V, to do this i have uses an op482 as omparator,
the configuration is this, +IN = -5V, -IN = Square wave, V+ = 15V, V- =
0V, but in the output i get a signal with a high value of 1.3, and a
low value of 0.3, some suggestion about what doing wrong, or another
solution to get the signal that i want, in addition i want to invert
the signal, is there any ic with i can change the voltage and also
invert the signal?
invert the signal?
