It is my pleasure to consult you about an electronic problem that I have faced while I was making a ''High voltage generator'' based on a small and simple circuit which is joined in this document.
The circuit is made and it is quiet functional, but after few minutes or sometimes just by switching it ON it gets damaged, and the components that always get burn are either the NE555 that generates the command signal, or the transistor put in sires between the primary of the amplifying transformer and the ground, which by its turn is commanded by the NE555, I have tried my suggested solution from few colleagues and so, but none of them was really useful, so with all my respect it would be a great pleasure if you manage to help me about this, and thank you
