osterchrisi
- Mar 8, 2011
- 28
- Joined
- Mar 8, 2011
- Messages
- 28
Hello guys,
simple question: I have a circuit running off +9V and (ideally) having an output of 8Vpp around +4.5V, so basically somewhere between 0.5V - 8.5V. So this is what is mostly referred to as a 'common ground'.
Now the question is: If I was to connect the single ended signal (say the output of my last opamp) with a cable that makes that signal refer to an external ground (which would be at 0V seen from my circuit), would that signal then become bipolar with 8Vpp and swinging around -4V to +4V?
I get it that with AC signals it would be a simple capacitor (+resistor) solving my problem but what about DC voltages? Does that work or not?
Thanks for all answers!
