Computer fan doesn't spin
ThomasWheeler
Apr 25, 2016
32
Apr 25, 2016
32
Hi, I have a Cooler Master 12V 0.16A PC fan that won't start spinning by itself. I need to push start it and only one led lights up instead of four. What aproach should I take to diagnose the problem?
davenn
14,260
14,260
check the voltage to the fan, make sure it's a full 12V
looks like you have taken off the sticky label ?
there may be dust in there or the motor drive cct is faulty
either way, a replacement fan is pretty cheap off ebay
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Sometimes you can lubricate the fan to get a bit more life from it. It's never a long term fix, but may work until you get a new one.
The bearing is often visible under the sticker (that you have removed) -- and yeah I can see it.
Bigrockk
Aug 1, 2016
17
Aug 1, 2016
17
I have "lubed" quite a few of these with good success, just make sure you use a light, non detergent oil. Using the wrong lubricant will just gum things up and make it worse. 3 in 1 oil works great and is readily available.
Good luck!
pharaon
Oct 28, 2014
444
Oct 28, 2014
444
if you want my advice use WD-40 and it will back as new
