What have you tried so-far that does not work? You might post some schematics of the circuits you have tried. Tell us your test results for each one, particularly, just how it failed to work.
Is this circuit being constructed from actual components, or is it being simulated?
If you are working in the hardware domain, what components do you have on-hand?
If you are using simulation software, what sort?
There must be additional design requirements. It would be helpful to know what these are.
How is this circuit to be applied or used?
What is the desired input common mode range? Input offset voltage? Output voltage range? Power supply voltage. Power supply current? Speed, or frequency response?
Commercial CMOS op-amps have input circuits that might serve as examples for study. Some semiconductor manufacturers provide "equivalent circuit" schematics on their data sheets.
Ted
