Circuit on state activates a second higher voltage circuit
Hey. I am sure this is simple, but I dont know the proper electronics
jargon to search for an answer. Basically, I want the completion of
one circuit to activate a second circuit but not allow feedback to the
first. I have an alarm clock running on a AAA battery, and when it
sends power to the buzzer (detached) I want it to activate a second
circuit running off a 9V battery. The problem is, I dont want the 9V
circuit to get back to the alarm clock, otherwise it would overload it
(Please correct me if I am wrong). Is there any way to do this
without causing major problems? Thanks.
R
Randy Day
The circuit below should work, depending
on the current needed by the 9v circuit.
The NPN transistor acts as a diode to block
9v from the signal input.
+9v
| | your 9v circuit
+v |
signal ___ |/
from -|___|-|
clock 1k |>
neg term.------+----- 9v battery negative terminal
clock cct
(created by AACircuit v1.28 beta 10/06/04 www.tech-chat.de)
Thecircuitbelow should work, depending
on the current needed by the 9vcircuit.
+9v
| | your 9vcircuit
+v |
signal ___ |/
from -|___|-|
clock 1k |>
clock cct
(created by AACircuit v1.28 beta 10/06/04www.tech-chat.de)
Thanks. I'll give this one a try.
C
Chris
Sure -- it's doable. But a simple transistor alone won't cut it, I'm
afraid.
Let's start our with your big question -- you're concerned that the 9V
will get in to the alarm clock circuit and let the smpke out. That's
a concern, but you can take care of it.
To begin with, your alarm is probably a piezo beeper which is driven
by applying the voltage to one side of the beeper (1.5V), and 0V to
the other side. It then switches the voltage back and forth at the
sound frequency (probably a few thousand times a second).
This output is floating (separate battery). So from the outside, it
looks like a 3V peak-to-peak square wave. You can feed that to a
voltage doubler with schottky diodes, and that should provide a high
enough voltage (about 4.5V or so) to drive a logic level MOSFET, which
can turn on your circuit. Take a look at this (view in fixed font or
copy&paste to Notepad):
| .------o------. |
| | 9 Volt | |
| | Circuit | |
| C = 0.1uF | | |
| D=1N5819 '------o------' |
| .-------------. |D ---
| | | C IRL2703||-+ 9V -
| | | || D ||<- |
| | o----||---o-->|---o------o---||-+ |
| | | || | | | G |S |
| | Alarm | D - C --- | | |
| | Clock | ^ --- .-. | |
| | | | | | |1 Meg| |
| | o---------o-------o | | | |
| '------o------o------------'
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
Tack solder two wires to the beeper element in the alarm clock. Build
the circuit with 0.1uF caps and 1N5819 schottky diodes. Then snip the
negative (black) wire going from your 9V circuit to the battery, and
attach the MOSFET in series as shown.
This will reliably turn on when the alarm is on. It may get a little
iffy at very low AAA battery voltage, though. The MOSFET selected is
beefy enough to drive any load a 9V transistor battery can supply.
If this is too complex, or if you need a quick solution and aren't
able to come up with the parts on short notice, you can use an
external 12V wall wart, use standard 1N4001-type diodes, and use a
darlington transistor to drive a relay. The relay contacts can then
be used to turn on and off your 9V circuit.
Please post again if this isn't clear, or you need more advice.
Good luck
Chris
R
Randy Day
One caveat, as another poster noted.
If the buzzer is fed by a square wave signal
from the alarm, this won't work.
If the alarm handles its own beeping, and is
simply switched on by the clock, it will
run for as long as the beeper does.
