D
DaveC
I know this subject of "cheap" and "calibrate" used in the same sentence may
well be anathema to some of you but I need to verify that either my IR temp
gun is accurate or my DMM/thermocouple is, or neither. Accuracy to 2 or 3
degrees F is fine.
I'm looking for suggestions for a simple way to provide some kind of common
temperature "standard" (I use the term loosely, here) I can compare these
against.
degrees F is fine.
against.
