John Sanford
- Aug 9, 2017
- 1
- Joined
- Aug 9, 2017
- Messages
- 1
Connect a 12 volt taillight, turn signal or any small 12 volt lightbulb to your 6 volt battery. Now connect a 12 volt charger to the 6 volt battery. Voltage at battery will be 6.7 to 7.02 volts. Unscrew the three caps on the 6 volt battery and observe the bubbles of hydrogen gas leaving the electrolyte from each cell. The cell on the + side will stop bubbling first as the 6 volt battery reaches full charge, then the middle cell will stop bubbling, then the cell on the -- side will just barely be bubbling when fully charged. The small light creates a drain and the charger continues to charge that cell.
A 12 volt battery connected to a 12 volt charger will cut out at 14.6 volts. Then the 12 volt battery will settle to 12.7 volts after 30 minutes.
A 6 volt battery connected to a 12 volt charger with the small 12volt light WILL NOT cut out because you want a fully charged 6 volt battery to settle to 6.4 volts.
You must observe and manually disconnect the charger.
Do not connect the small lightbulb in series because the 12volt charger will sense too much resistance and then indicate a fault after two minutes.
