Richard9025
- May 24, 2016
- 205
- Joined
- May 24, 2016
- Messages
- 205
Hi !
I salvaged a 455khz ceramic filter from a CB radio , but I cant find any datasheets or relevant info on the internet
Some photos :
If you can't determine which pin is which , I can take some photos of the radio that it was extracted from (eurocb micro 2) , maybe a schematic and the photos will get the answer .
Now with the BFO (it is based on the model from IK1ZYW http://spazioinwind.libero.it/ik1zyw/hardware/osc455.html)
In the following schematic I assumed that pin 1 is output , pin 2 ground and pin 3 input :
The votage regulator works , from an input of 9V i get 5.1V
Now , to test if it works , I connected it to an SDR , but I can't see the oscillation on 455khz :
With it connected , I dont see anything , no change
But if I rotate R2 (a multiturn , 10 turns , pot) or I just get near the bfo , look at what happens , if I get away , it dissapears :
Yeaa , messy stuff
Thanks !
Some photos :
Yeaa , messy stuff
Thanks !
