cascade amplifier with common emitter amp and common collector amp
majdi
Jul 10, 2010
33
Jul 10, 2010
33
I need to find IE1, IE2, re1, re2 and overal voltage gain.
First i should open all capacitor first right?. it should be like this:
How possible i can calculate since there dont have enough value in this circuit? like Ic or Ib.
Harald Kapp
13,725
13,725
Start by noting that for each transistor IE=(1+beta)*Ib
Set up the equations applying Kirchhoff's laws and solve for the operating point.
majdi
Jul 10, 2010
33
Jul 10, 2010
33
Here my final draw:
IC1 = IB2
IC1 = VR1/R1
VR1 = Vcc - (Vceq1+VRE)
or
Vceq2 = Vcc - (VR4 + VR5)
I should find IB2 first..let me think........
Harald Kapp
13,725
13,725
IC1 <> IB1
IC1 flows through the collector of Q1, not into the base of Q2.
IC1+IB2 = VR1/R1
majdi
Jul 10, 2010
33
Jul 10, 2010
33
IE1 = (VCC – VCE) / (R1 + R2 + R3)
= 12v – 0v / 20k + 2k + 8k
= 12v / 30k
= 0.4mA
Let assume VCE Q1 = 6.0v
= 12v – 6v / 20k + 2k + 8k
= 6v / 30k
= 0.2mA
VE Q1 = IE1 x (R2+R3)
= 0.2mA x 10k
= 2v
VB Q1 = VE1 + VBE1
= 2v + 0.7v
= 2.7v
VB Q2 = VCC – (R1 x IE1)
= 12v – 4v
= 8v
VE Q2 = VB Q2 – VBE Q2
= 8v – 0.7v
=7.3v
VR5 = ½ x VE Q2
= 3.65v
*VR5 should be near to VB Q1 = 2.7v, this show IE1 is too low, we need to increase it. Try IE1 = 0.3mA
= 0.3mA x 10k
= 3v
VB Q1 = VE1 + VBE1
= 3v + 0.7v
= 3.7v
= 12v – 6v
= 6v
= 6v – 0.7v
=5.3v
VR5 = ½ x VE Q2
= 2.65v
*VR5 should be near to VB Q1 = 2.7v, this show equal to VB Q1 to low. Try with IE1 = 0.25mA
= 0.25mA x 10k
= 2.5v
VB Q1 = VE1 + VBE1
= 2.5v + 0.7v
= 3.2v
= 12v – 5v
= 7v
= 7v – 0.7v
=6.3v
VR5 = ½ x VE Q2
= 3.15v
*This result is close for VB Q1.
Let IE1 = 0.24mA
= 0.24mA x 10k
= 2.4v
VB Q1 = VE Q1 + VBE Q1
= 2.4v + 0.7v
= 3.1v
VC Q1 = VCC – (IE1 x R1)
= 12v – 4.8v
= 7.2v
VB Q2 = VC Q1
= 7.2v
VE Q3 = VB Q2 – VBE Q2
= 7.2v – 0.7v
= 6.5v
IE2 = VE Q2 / (R4 + R5)
= 6.3v / 2k
= 3.15mA
So: IE1 = 0.25mA and IE2 = 3.15mA.
re1 = VT / IE1
= 26mV / 0.25mA
= 104 Ohm.
re2 = VT / IE2
= 26mV / 3.15 mA
= 8.25 Ohm.
IB1 = IE1 / Beta
= 0.25mA / 100
= 0.0025mA
IC1 = 1+Beta x IB1
= 101 x 0.0025
= 0.253mA
Av1 = IC1xRC / IE1 x re1
= 0.253mA x 20k / 0.25mA x 104 Ohm
= 5.06v / 26mV
= 0.19 v
Av2 = 12v / IE2 x re2
= 12v / 3.15mA x 8.25 Ohm
= 12v / 25.99mV
= 0.462 v
Harald Kapp
13,725
13,725
Why should this be so?
What about IB2 which also flows through R1?
What makes you think so? Why not 5V or 7V?
Some equations to work with:
IE1=(1+beta)*IB1
IE2=(1+beta)*IB2
voltage across R5: (IE2-IB1)*R5=IB1*R6+VBEQ1+IE1*(R2+R3)
I hope that helps.
